Clutch dragging upon warmup
flashyboyz
Clutch dragging upon warmup. Idle raises and lowers with clutch pull. With a cold engine , I pull full choke, start the bike and observe a rough , low RPM idle when the clutch lever is NOT pulled. Engine speed RPM increases when cluch lever is pulled as well a smoother sound occurs. After bike fully warms up the idle will hardly change when clutch lever is pulled and rlaeased. Any help would be appreciated.
That means the TRE is working.
