clutch fluid leak
busarider2013
So am getting some kind of slow leak somewhere or something from my clutch fluid can't find where it is but ever 2 week or so I have to fill my clutch fluid as i lose my clutch....where do I look too see if I can find this leak or ??????? Any ideas I have a leak from the cover at the top but I fixed that and don't see no more leaks there
Follow your clutch hose down to the slave cylinder.
Do you see any wetness on the hose any where or at the hose connection to the slave cylinder?
You may have to remove the cover for the front sprocket to see if it is leaking inside that area.
Hope that helps.
My plunger on my clutch lever was leaky. It would drip down on the ground and I never saw it. Drove me nuts for awhile. Finally was in a lean and a drip dropped across and down onto my gauge clear plastic. Lightbulb went off and I found it only leaked when you depressed the clutch lever. New one was like $30 at the dealer. Took about 30 minutes to change. Then bleed and I never had another issue.
