Hi, i have noticed that my clutch fluid is turning darker compared to the brake fluid. Anyone know what is it that is causing the clutch fluid to turn dark quickly?? Thanks in advance.
Do a search on here,alot of people have had this problem,including me..
Your clutch slave cyclinder is dirty..
It picks up dirt and oil from your chain..
Its the inner hose degrading.Time for new braided lines.Power steering hose does the same thing.The inner liner breaks down and contaminates the fluid.
Its 2011 busa, with only 14000km on it.. how can it degrade so quickly and the brake hose is the same age as the clutch hose, why hasn't the brake hose degrade??? Its a stock bike, no mods done..
It's not happening on the brake side because it's make A LOT more sturdy on the brake end of the bike, as more pressure goes to the brakes than to push a dinky little shaft into the tranny.
Check the garage floor under the kickstand after the bike has sat for a couple of days. If there is a spot there, or a stain that wasn't there before, you have a leak on your clutch slave.
I really don't think the rubber line has deteriorated in one year.
Make sure everything is bolted up nice and tight. I think that air/moisture is getting in there somehow (most likely clutch slave rubber seal around the piston).
You've tried just flushing it out with fresh, high quality fluid I'm assuming?
