G GSXRFANN FLUNKIE Donating Member Registered Jun 6, 2006 #1 What size is that dang clutch hub nut. I tried a 27mm, but it was too small!!! Help!!!
B BusaCruise speachless Donating Member Registered Jun 7, 2006 #3 it's in the 30s .....32 or 34 me thinks .....your try referencing the post shop manual?
hydrabusa Donating Member Registered Jun 8, 2006 #4 is it in the manual? or not? hmmm...let me look...
hydrabusa Donating Member Registered Jun 8, 2006 #5 It doesn't say about the size, but how much torque...sorry can't help
B BusaCruise speachless Donating Member Registered Jun 8, 2006 #6 break off a piece of ruler and measure it.
rubbersidedown TURBO-BUSA-RIDIN'-BASTID Donating Member Registered Jun 8, 2006 #7 Yer also gonna probably require an' air gun,or a special tool to stop the hub from turning while trying to remove it. Why are you removing it? Rubb.
G GSXRFANN FLUNKIE Donating Member Registered Jun 8, 2006 #8 I am doing the clutch mod. It was a 30mm, and I had to use my impact wrench to get it off. Thanks for the info though!
