Clutch Issue
sisco213
I have an 02' with 13,000 miles on it. After sitting all winter my clutch no longer works, it has no pressure. Can anybody help?
Meaning when you squeeze the lever it has no resistance? Or does it constantly stay engaged?
Probably need to rebuild the slave cylinder and refill the fluid on it.
--Wag--
exactly, the fluid has all run out (open the top and take a peek).. Slave probably leaked it out over the winter..
If you fill it up and bleed it it may be OK.
The seal might have just dried up and leaked or shrank in the cold.
Try it - nothing to loose.
Check for leaks after, you don't want it to let you down when you are out somewhere.
Hey...Welcome!
:welcome:
