clutch kill switch
jeebuss1
Is there anyway to disenguage the kill switch behaind the clutch? The switch is enguaged when the clutch is released.
I bought some aftermarket levers whitch does'nt have the little nub on the clutch side to disenguage the kill switch. I'm just looking for a way around this. Thanks
I think it is actually closed when you pull in the clutch (N/O switch)
A simple jumper wire will work (unless it engages some relay full time closed.. then you would need a momentary "on" switch wired in...
IMHO, any lever that does not come with the correct nub, is probably not worth having on the bike.. (if they cut that corner, what else did they skip? like quality metal?)
go with pazzos man shorties. one of the best mods i added to my busa 174 to my door Next day air
Glad you got it working but for future reference...Don't disable it. It is a sensor the ECU uses in it's calculations even including lowering the rev limiter.
