ive noticed when i pull the clutch in in 1st or 2nd or sometimes just idling it makes like a whirling sound or like a whining ive never heard it before but maybe i just never noticed it is this normal
Gen 1 or 2, if its the Gen 2 check your bolts that are inside the clutch basket, there was a recall where the bolts would back out because of lack of locktite, if it sounds like a rattling sound thats your problem!
If its a loose clutch basket bolt you have repair it ASAP as the scraps from the cover might cause damage.Leave the bike on its side stand an simply remove the clutch cover(minor loss of oil..if you're not going to change it).Search for scratches to the inner side of the cover and if there are some , remove bolts gradually and locktite all of them before retightening![]()
Probably.....My dealer,as a close friend,introduce me that way of fixing it....a year ago.I believe you have earlier informations.I never had that issue with mine ...but I like to be always readyMic I'm not sure but I think there are some improved washers that are used when performing recall a dealer ?
the issue with the basket bolts is not a recal....just a notification.It can happen anytimei called the dealership and they said the 09 didnt have any recalls and ran my vin and said that nothing was recalled on mine???
Here you are....do u know where i can find this notification so i can show them
