Depending on how wild you really want to get, a hand clutch will hold up to well over 250hp. We've got a RealStreet bike, that last summer made 302 on a weldup hub with HD springs on an otherwise stock clutch. It does have a stock sprocket cover too iirc, though i could be wrong about that. The same bike went 8.51 at the finals last fall at 176mph, and should go WELL WELL beyond that this year, with the same stock clutch and HD springs. If you're really dead set on a grudge bike, good luck getting that kind of info out of fellow racers. the guys heavy in the grudge scene wont put their clutch setups out there typically. If you want to be slick, a Hays is going to be the least noticable, still rideable(somewhat) on the street, and can still hand clutch it at high rpm, where a multistage will make high RPM hand clutch shifts, like on the street, will be difficult with a well setup multistage lockup.
