OB_daddy long stroke
got my clutch apart...fibers all look good... metals definatly got heated up (most of the outside plates are completely discolored), back ones less discoloration, but still show burn, or, blue, spots in about 3 locations..when i lay them flat on a glass table and put my finger on on side, the other side BARELY comes up on opposite side, and i mean barely, probably 3 thousants, or just barely enough to see a tiny bit of light through. when i put very light pressure (weight of my hand) on side that is up in the air, it flattens out no problem...is very slight warpage o.k.? or can they be sanded and put back in?
thanks-
thanks-
