mrnyc01
Hey guys.. got a quick question..
I changed my oil recently.. as I have done for many years in the past. This was done last weekend. I noticed I has a small oil leak from the drain plug. So this past Sat I put a oil pan under it.. drained the oil (which by the way is brand new) and took the plug out sealed it and put it back in. Poured the oil back in since it was new and I only rode the bike about 10 miles since the oil change to test out my new exhaust tip. Didn't see a need to spend money on MORE oil. Here is the prob..
Went to move the bike back to its parking position in my garage and I found out that with it in gear, when I pull the clutch to move it around (without turning it on) it was difficult to move. I had to put it in neutral to move it freely. I was like wth? So I started it, sat on it and put it in first, and it was a strong jerk into first. Did it a couple of times. I didn't let the engine run long cause I wanted the sealent I just coated the drain plug with to set.
I used reg (although better grade) 10w/40 (dont blast me for this.. I change my oil twice a season)
Also in the past, even on other bikes it was no problem.
Did I need to let it run longer to build up some type of pressure or something? This has never happened before. And when I rode it to test the tip... it rode fine.
Thoughts?
Thoughts?
