NIGHTFLIGHT
Banned
Little dif than stock set up.Im useing a hydraulic clutch release 2 hold in cable so I can leave on a button on top yellow +use delay timer.Normaly I do burnoff in 2nd then put in first ease up 2 line in 1st gear then after turn on top yellow put thumb on button +let clutch handle out.2 my horror 2 night in last time run+1st elimination pass it lurched forward little+died on me.TAKE IT OFF TRACK TRY AGAIN IN PIT WORKS FINE LIKE NORMAL.So as soon as clutch cools down a bit dont do it.I think my clutch is pulling a little.I bought back in and was advised after burnoff put in neutral and just take 2 line like a kick+go then clutch not so hot worked ok.DO you think i got a toasted clutch plate?If I only find a couple roasted can I buy singles or have get entire set.
I did salvage a 2ND PLACE
