I have recently purchased a 2000 Hayabusa. It is in very good general condition, although I did need to replace and rebuild the front brake master cylinder and calipers. Front brakes very good now.
The clutch was very light and only engaged at the end of the lever travel, so I rebuilt the master cylinder. This did not cure the problem, I now had no clutch. I then replaced the seal in the slave cylinder, the rest of the components looked OK. No leaks.
When I operated the lever with the cover off, the piston moved out and I was not able to push it back, so pressure looked good. I reassembled and the lever was still light and no move on the clutch. I have bled the system in both diections and have replaced the DOT 4 brake fluid. Still no joy.
Any advice?
Any advice?
