clutch push rod
HAYABUSA020
hey, i broke my clutch push rod clean off when changing my front sprocket.the seal is not damage,but i push the rod in when trying to get out,can anyone help.
unless you have a small diameter magnet pickup tool to slide into that hole and pull it out the easiest way I can think is to pull off the clutch cover, the 5 clutch basket bolts, pull out the bearing piece and then slide a small dowel into that hole and push the rod out from the other side? Think that may work
Get the cover off and break the seal. Depending on when removed last the gasket might come off in one piece and possibly be reused. The center bearing piece simply pulls right out.
**IGNORE MISSING CLUTCH SPRING BOLT** I broke mine doing clutch inspection and waiting on one to arrive to put back together
The hole left should be able to push the push piece out the other side
