Fireman_on_a_Busa
I finally got around to replacing my clutch and I have taken pictures of start to finish, but will post them one by one, so there might be some gaps in the sequence. I noticed that my clutch was slipping because in the higher gears around 8,000 rpms the bike would jump and the catch itself. I have a total of 32,497 miles on the original clutch. I have not checked out my work yet, since when I finished up it was dark. I will keep you posted. Ok the parts that I used were OEM parts with the exception of the main fibers due to a back-order wait of about 2 months, so I ordered aftermarket. First thing to do was do drain the oil. Then remove the right side fairing exposing the clutch cover.
