clutch reservoir...hmm
TonyMastodon
Big Blue Burrito!
So I just filled it up a few hundred miles ago and now its starting to drop down to the low line again...anyone know why this is doing that?
booooooooo =(.... easy fix?... ive replaced them in a car, but not on a bike.
Yes, just remove the left side panel...then the slave cylinder. R+R the seal
and clean up the area, lube the rod...re install the slave cylinder, then top
off the master and bleed the system.
of the master and bleed the system.
ahhh, easy enough.. THANKS!
Guess thats next on the list!
