clutch reservoir lost fluid
jwcfbd
I'm putting these pics. from the 99-00 manual because of a member that suffered fluid loss for his clutch reservoir while his bike was in storage. If anyone has had this happened to them please let us know what you found and how you fixed it.
The only thing I can think of is to pull the actuator housing and see if there is any fluid behind it. There is a piston that pushes the actuator rod on the clutch and if the seal on that let go the housing will be full of fluid.
