All of them if you don't carry a plug kit as well.........I'm going to pick up a CO2 inflator to carry on the bike for the long trips. Does anyone have any idea how many cartridges it would take to fill the rear tire after a flat?
Does it hook directly up to the battery, or do you need to install a jack somewhere?My local Walmart now sells the Bell line of motorcycle equipment. I picked up a nice plug kit in a zippered case for about $6 bucks. The CO2 kit is $12.00 with one cartridge. It says you need 3 to 4 to fill a completely flat tire. I believe a 3 pack of extra cartridges was $8 bucks.
I passed on that, by the time you add things up it'll cost you $10 just to fill your tire once.
Went to Meijers and picked up a mini 12 volt air compressor by "Slime". $10 bucks, fits in your hand and use it as often as needed. Size isn't much bigger than the CO2 kit when you factor in the 3 extra cartridges. If you take it apart and ditch the plactic housing it's smaller yet. It does draw a few amps so I'd make sure the bike is running when using it, otherwise you may go from a flat tire to a dead battery.
PM Ludicrous Speed. He's got an on board compressor wired up to fill his shifter tank. I'm sure he'll tell you how to do it.Does it hook directly up to the battery, or do you need to install a jack somewhere?My local Walmart now sells the Bell line of motorcycle equipment. I picked up a nice plug kit in a zippered case for about $6 bucks. The CO2 kit is $12.00 with one cartridge. It says you need 3 to 4 to fill a completely flat tire. I believe a 3 pack of extra cartridges was $8 bucks.
got pics of the tire pump?My local Walmart now sells the Bell line of motorcycle equipment. I picked up a nice plug kit in a zippered case for about $6 bucks. The CO2 kit is $12.00 with one cartridge. It says you need 3 to 4 to fill a completely flat tire. I believe a 3 pack of extra cartridges was $8 bucks.
No problem.Thanks for the Pic, much appreciated. I will see if I cant find something like it at Fleet Farm.
