Co2 or air shifter
RJB
Co2 or air shifter what one would you perfer and why??? i am looking into geting one and was wounder if one ws better than the other and if so why
ummm...I may be wrong here but they are the same thing right???
I always understood it as an air shifter used Co2
If they both use the actuator then i would say the air shifter because you don't really have to pay to fill just hook the tank up to your air compressor....that is you are me I have access to an adapter to connect to Co2/air tanks
I posted on your thread at the "other" board, but forgot to add why I like the onboard compressor with a tank.
My system has a slow leak. For the life of me, I cannot find it. I have sprayed soapy water on all the fittings and can find NOTHING! That means I would go through a lot of CO-2.
Also, with an air sys. (vs CO-2) all I do is flip the switch and I am ready to go. No stopping and turning on a valve. Some people do not have a valve, but for the above mentioned resons, I would think they are a good idea.
BTW, check MPS
