Co2 Routing
Kevin Jones
With the tank mounted in the back on the swingarm, how do you have your lines routed for ease of pressurizing? I basically do it from the top of the tank but have to be off the bike and open it before I ride. Now with the integration of the AMS, its even more important I have some sort of way to open a valve up front. Can you show me some of your configurations?
How big is the tank?
Why not put it in the undertail?
Do you just have a tank, or a compressor too?
Actually that is a killer idea for how to split the co2 from AMS to shifter. The arm already has a tank that I use for the shifter, I will just use a T before the tank, run one line to the AMS and leave the other in the arm. I still cannot figure out how to get the valve to open the tank up front. I did see oldgixxers setup and he has a small tank up front mounted somehow in the nose with an accessible valve cut through the by the dash.
