jermzfree
While I am waiting to do a leak down test on my Busa, I had a question about the compression readings I got.
Checked the motor warm, with throttle pinned open and got 160 psi across the board. Checked the manual which said rebuild if all readings are under 171psi. But that does not make any sense to me since the minimum psi is 128. The bike runs great, no smoke, hesitation, and plenty of power. I also double checked the readings to make sure I had the tester in right.
If it runs great should I not worry about it?
