OB_mbuehler
Pulled everything off the bike, disassemebled the turbo and cleaned out all the oil. Gasket acutally looks OK, it's just cut funny so a bit extra hangs out the bottom of the turbo. Cleaned oil from the turbo all the way to the throttle bodies, the stuff was everywhere. Checked out the suspect line, looked OK to me. Reassembled everything, even used silicon for anything threading into a place where boost could escape. Fired it up, and took it for a spin. Same crap happening. No boost, leaking oil, and when I got back and pulled the airfilter, oil poured out. Waste gate has been venting, but I'm not seeing any boost (either feeling it, or the tell tale gauge showing it). Mr. Turbo is closed on the weekends, so any thoughts?
