ALLshow.NOgo
Well I proceeded to walk outside the front door of my Apt. and I saw I can of something on my door matt close to the door. Upon further inspection it was a new 20oz can of Maxima's Racing Oils Chain Gaurd. It was brand new and still had the tag on it. I used it too because I needed it and the stuff works really good. Shoots stream far so you can get into the chain gaurd area as you could not with conventional spray lube. Kinda foamy after you spray it. Wish I knew who it was from
Chain Guard
Synthetic, Clear, Clean
Contains no CFC's!
Maxima Chain Guard is an advanced chain lubricant specifically
formulated for today’s on and off road, high performance motorcycle chains. It is compounded with the finest petroleum lubricating bases and reinforced with the most advanced anti-wear and extreme pressure additives available. It also contains special additives to prevent “fling-Off†and protect against rust & corrosion. Chain Guard is o-ring safe and makes an excellent lubricant for all motorcycle control cables.
Features
Extends chain & sprocket life
Easy application
Race proven protection
Will not fling-off
Waterproof & heat resistant
Safe for all o-ring chains
Excellent rust & corrosion protection
Chain Guard
Contains no CFC's!
Features
Easy application
Will not fling-off
