CrotchRocket
My busa is lowered 2" on the rear and 1" upfront. I have always worried about scraping when leaning her over more aggressively. Can anyone with this setup confirm this?
As long as you don't ask much out of her you won't have any problem.
If you want to romp her in the canyons I'd suggest you hit the gym on a regular basis because it's going to take some muscle to tip that fat heifer in at any sort of speed.
Beautiful bike. Should really attract lots of attention parked in front of Starbucks on Sunday morning!
"Beautiful bike. Should really attract lots of attention parked in front of Starbucks on Sunday morning! "
OUCH!! That burns gotta hurt....
cheers
ken
Your cornering clearances from hard parts to the ground have been reduced because of lowering the bike. You will not be able to lean her like a stock bike. Keep the balls of your feet on the pegs and that will help from scaping your boots, but it may still happen. If you plan to put her on the track, do yourself the favor and raise it back up. If you have soupy links, you can do that easily. Keep in mind, if you start scapping hard parts, you are on the edge of that fine line that you will either make the corner or lowside. Nothing wrong with having a lowered bike, as long you are also aware of the results and what this translates to on the road.
My busa is not lowered and I scrape the lower fairings when riding the mountains, so I would imagine that being lower, you will have serious scrap marks.
Thanks for your insight, luckily, I have soupy's links. I lowered her because I'm vertically challenged
If you are scraping the lower fairings when riding, you are riding at the tires edge...sounds like a pending low side. I guess you have pulled or scrubbed off the peg feelers?
