Goddamn! That thread is gold! Thank you, I think it should be stickied...Several members here have done it. Like the Gen1 and 2, it is still a personal opinion. If you check out the What Have you Done to your Gen3 thread you'll find lots of pics. I did it to mine. What did you do to your Gen 3 today? | Gen 3 Busa Information
It's a 4 piece design. Makes it much easier to work on. I just used a dremel with a drywall cutting bit and then sanded the edges and lightly burned them with small propane torch to remove any other roughness.Does anyone have pictures of the actual cutting process or at least pictures of what the underside of the hump looks like in detail?
It can be done with a Dremel with the round filing/sanding bit. That's how I did mine. Mark the area to cut and go very slowly with the Dremel, stop and test fit multiple times until it sits properly.
I don't have any, but can take some. I see this is the second time you have been looking for pics, so perhaps a little more detail of what you are looking for will help. Understand it can be kind of intimidating cutting the plastic, so just want to ensure you get what helps.Do you have a photo of underside of your hump? Or a closeup of the cutout edge area?
actually this is on point, have any more pics? did you gain much opening it up? Looking to stuff a small 3 ounce Co2 in the back and she's pretty full with the maxxecu and ignitor in there now.It's a 4 piece design. Makes it much easier to work on. I just used a dremel with a drywall cutting bit and then sanded the edges and lightly burned them with small propane torch to remove any other roughness.
Didn't gain much. Could have gone even more but want it to still be strong. Can fit a pair of gloves easily. I can almost shove a standard Jansport backpack in there but it takes a few minutes trying to roll it and shove it.actually this is on point, have any more pics? did you gain much opening it up? Looking to stuff a small 3 ounce Co2 in the back and she's pretty full with the maxxecu and ignitor in there now.
I think we've all locked the hump LOL, I know i did it on my gen1 way back when it had a stock rear tail section 128 years agoI've forgotten to put the kickstand down, and dropped the bike on its left side. While doing the grab rail / top case mount cutout and holding the hump upside down in my lap, I've gotten front and rear confused during the Dremel but that wasn't the fatal mistake. Despite knowing better, I clicked the hump closed and locked without reconnecting the Locking cable. So that was a quick hump replacement.
You're in good company
Im glad you said this, honestly I thought I didn't know what I was doing it my maxxecu was interferingDon't know if anyone has this problem but it always takes me a bit of finagleing to get the hump locked it. Adding the taper isn't as buttery smooth as the Gen1 hump engagement but it is an improvement.
