mracer29
Lights are finally done on the bike. 168 lights total, 22 connectors, led light controller, and 16 ft of speaker type wire.
First I got 2 rolls of led light tape off eBay for $13.75 each.
I got a roll of speaker wire for $14.99 off amazon.
25 male/female led connectors.
1 led controller with remote $14.50 eBay.
I first got enough wire to run front to back of bike.
Then separated the wires where the connections would be.
Made and arranged all connection leads.
I then connected and soldered all leads to the main wire, I used liquid electrical tape then electrical tape at connections. Then put the wires into wire loom.
Made all my lights.
Did a small test to make sure all was working as expected.
http://youtu.be/VkHYI0Bkijs
Today I installed the custom made wire harnesses and connected all lights.
http://youtu.be/VgkXRznb2h4
Only thing I want to change is the lights in the ram air tubes. I installed them from the rear of the tube so I didn't have to take the bike apart to get the tubes out. One of these days ill remove and install lights towards the front of the tubes for better lighting.
I have enough lights to do 2 more bikes if I buy connectors and a controller.
Made all my lights.
