(Cloud9 @ Jul. 20 2007,11:55) If it was running good before in those ranges. You could try to take the values out of the old map and place in them in the new map at the range you are having difficulty. Make sure you backup your current map before you start messing with it...
If you don't have anyway to get a hold of an A/F meter, you could try using the course tuning buttons to lean it out in the low range and see how it runs. If it is surging, it generally is rich, but if it runs worse, richen it up a bar instead and try it out.
Definetly a mapping issue. Can take many runs and tuning hours to get the custom map right. It is not a one-time deal usually and requires lots of tuning time to get it perfect.
