shanerz07
Any Busa riders, I am having a mechanical problem and I am in need for some intell. My 2007 Busa is cutting out in first and second gear for a split second and then comes right back. It only happens when I twist the throttle hard. The bike cholts when this happens. This takes place from 6000 to 8000 rpm range. Any help will be most appriecated. If you ride at normal speed and shift gears at normal speeds you don't feel anything. When jam on the throttle you feel this in first and second gear only and the rest of the gears I am just tearing up the blacktop..
