I had no problem till today on the way to work when I was cruising about 7 grand and the bike cut off like a hit the kill switch and then the fi started to blink I then started it up and ran for 2 minutes then did it again this happened like 3 times in my 20 minute ride to work.I did a search and here is my check list from 1st to last:kickstand switch,pc connection,pc reinstall map,disconnect pc,disconnect tre.My question is anybody had same problem or any other thing to check
? Also idle is fine 1100 ish and when it cut off I was on the gas.
<!--EDIT|busa boyz
Reason for Edit: None given...|1125929103 -->
<!--EDIT|busa boyz
