Screwy
Hi guys I would really appreciate some help on this, I have a 99 Busa with a turbo,(the problem was there before the turbo was fitted) I have a brand new PCV (and I've tried another one too with no difference),the bike will run super smooth with AFR steady and fuel pressure steady,then without doing anything she will start to missfire Buck and cut in and out,the AFR goes wild from max rich to max lean fuel pressure is steady (just about) when this happens,then after a while she'll run sweet for a while? Are there any sensors that could be at fault? There's nothing on the F1 codes ether,I'm totally stumped! I really would be most grateful,thank you
