Johnny,small bottle in trunk - works well with limited space of Motorhead undertail
- good for about 60~70 shifts.
how did you get the vorex rearset to mount up with the spencer mount,its set up for stock rearset (something they dont tell you)?? i sent mine back and got a gatlin bracket,it mounts to the stator cover and is hidden under the fairing...ill post a pic laterI use the Spencer lower mount for the air cylinder, but everything else to do with the airshifter is Matt's system.
I'm pretty sure it's a 3.5 oz bottle. I paid quite a bit for mine off of a paintball site, but Matt now has them pretty cheap - $22 per bottle I think. They don't last as long as the 9 oz, but they are so easy to change that I can swap it out with a fresh one in minutes.Johnny,small bottle in trunk - works well with limited space of Motorhead undertail
What bottle did you end up going with?
The only thing I saw that didn't fit right up was the clamp that attaches to the shift shaft was too small (Spencer bracket on Vortex rearsets). I just drilled it out a little and then it worked fine.how did you get the vorex rearset to mount up with the spencer mount,its set up for stock rearset (something they dont tell you)?? i sent mine back and got a gatlin bracket,it mounts to the stator cover and is hidden under the fairing...ill post a pic later
Matt's system includes a small pressure gauge. It fits perfectly in the little hole in the right side of the frame - see attached pic.I have a small gauge on my Stem that I can see how much air I have.. works real nice.
