Thank you, Freechance and thanks also for posting helpful info on this thread I recently started.
https://www.hayabusa.org/forum/gen-ii-busa-information/167745-bent-header-bolts.html
That problem is now solved but it would seem I now have another problem that is directly related .
Well i would get u a metric tap i believe its a 8mm x1.25..but maybe someone can chine in on that size..
The exact bolt is
m8 x 1.25 x 25mm.
U really got to make sure the bike is cold when u take bolts out of aluminum because it can mess the threads up..not saying u did that..or corrosion or something on the bolt...
LOL, I am so incredibly slow at wrenching, that engine had to be cold as a stone when I took the header bolts out!!
Actually, the bike had been sitting for at least a week so the problem could not have been that the metal was too warm. Good tip though, thanks!
i usually try to use new bolts or clean the old ones really good..i usually find a nut and make sure it goes on the bolt easy if u reuse bolts..but sometime the threads mess up taking the bolt out...
I did end up replacing 2 of the bolts because they were bent. As you mention, I prolly should have bought all new bolts just to be safe. I did run a M8 bolt over every one of the header bolts and it spun freely over all but two. I replaced those two bolts.
I am super careful when I wrench and I even removed the header bolts with the thought in mind that they could damage the soft aluminum threads in the block. They all came out easily after they were broken loose. I don't think there is much I could have done to avoid the problem I have so I feel a lot better. One of those things that might have happened and gone without mention if I had the exhaust installed for me at a shop. I guess I put more effort into starting that bolt when putting it back in. That did not help. lesson learned. Glad I did NOT go harder trying to get that bolt started.
i think u will be fine with good bolts and working a tap in slow..i would not run the tap all the way in just put it in a turn or so the back out cleaning the tap each time and use some lube on the tap..until u can run the bolt in easy by hand..
Thanks, Freechance. I feel 10x more confident now. I will pick up a new m8 x 1.25 x 26 SS bolt today at Ace Hardware and find the right sized tap to run through the bolt hole in the block. I'll post up the results on this thread///Thanks again for all of the help.
Daron
