You can't adjust them.............. Sorry
all you would need is a variable resistor module (the device you would move back and forth to dim) and interrupt the power for the LEDs which is easy. Its the pin farthest to the right on the first row...
MC Mustang has one on his bike. Yet again I refer to him he just has it all
Yes, and that's cool if that's how I end up getting it done, by a remote mounted knob(I've been wanting this done for a while now too). I asked if there was any way to use the 2 buttons on the gen2 dash for it. That's what he's looking into also.
Should be easy. Dim module and a remote.. just interrupt that wire.. Which two buttons are you referring to? The clock and odo buttons? Or other buttons not on the gauge cluster
Yeah, those two, on the cluster.
If you wired them for dimming you would never be able to use your clock or switch trips again unless you reversed it. Its possible but would take a good bit of work. You could use any dimmer. You would just have to open up the dimmer you bought and solder some wires and run them into the gauge cluster to those buttons. Definitely some work lol. And also taking those buttons out of their current circuit...
Yeah, adding a function to them is the question. I can read wiring diagrams/blueprints, solder, and have done alot of electrical assembly. But beings as I'm red/green colorblind, it makes things a little more time consuming and sometimes frustrating Anymore I just like to ask and let someone else do these things
