OB_KawAbuser
I just want you to know that the rubber *wellnuts* that retain the windscreen become deformed over time. When you try to remove them to clean the windscreen or replace the OEM with a Zero Gravity, you may have a hard time pulling them out. Rmove both screws and jiggle the screen about to help them line up with the fairing holes and grab them with a pair of needle nose pliers(put blue masking tape on paint in the surrounding are to protect paint if you slip). Suzuki will sell you new ones for about $5.00 each.
The rubber pieces become deformed under compression and a ridge sets in the rubber making this a pain the a.s.s. to remove and install. If you buy a new screen order new rubber retainers from Suzuki(the Lockhart pieces are not the same).
You can also try cutting the ridge off with a razor blade - Be Careful!
Save the ZG plastic bag and store the OEM in it.
