Diff between rear shocks
thduke1
Hey guys.... Probably a stupid question but here we go. I have read that the 08-11 busas rear shock is more stiff than my 03. Is this true? And if so, how can I tell the difference between the two? A buddy of mine has a stock rear shock but, can't remember if it came off of his 08 or not. I just don't want to go through the trouble swapping them if they are the same shocks. Thanks again for your help.
Not sure, I know All things chrome has a heavy duty spring, I got one on order. Why ya lookin into a stiffer spring?
Because my bike is lowered and stretched and my fiancee rides with me a lot. I had to raise it up a little because it rubbed a hole in my undertail. I would like to lower it down a little bit more.
get a new spring and it will solve your problems, the problem will still be there with a stock shock of gen 1 or 2.
Sounds like me, but I wouldnt let the ex on last year, i new it would rub. Id call up All things chrome. Ive looked for other shocks and the only thing I found was custom work.
2007 HAYABUSA CHROME HEAVY DUTY- SUPER SPRING - eBay (item 380318764617 end time Mar-23-11 09:51:00 PDT)
WELCOME
Same guys, different ordering method
WELCOME
most suspension companies can sell you the correct spring. wouldnt be chrome, but i wonder what the constant flexing is gonna do to that chrome.
Peel it off with any luck, it may not even last till i put it on. Tryin to stay away from the chrome bug, may sand and rattle can it before the install.
I read in another thread that the gen 2 springs were more stiff. Is this not true? If not that kind sucks.... I was hoping to save that money for other ridiculous unneeded but shiny see yourself in it things :laugh:
they may be "more stiff" but if youve stretched your bike its irrelevant as neither are intended for your wheelbase.
+1 The Gen2 spring may be "stiffer" but it's not going to be a huge difference.
Just talk to any of the shock companies that have repalcements for the Hayabusa. They'll tell you if there's a difference in spring rate between the two generations.
I have an 08 spring on my 04. Not much difference. They are supposed to be valved different with stiffer spring. My impression is it is a fresh shock and really not much of an improvement. Go aftermarket rather than bother switching to gen II.
I am also in the process of getting that exact spring to help save my tail. Id recommend that route. Im running a gen 2 extension and lowered a bit and the stock spring does NOT cut it at all. Good luck man:beerchug:
