Difference between PC3 and PC5
You can do a LOT more stuff with the 5. You can map each cylinder, switch back, and forth between maps. Just go to their site.
It says for 09 & above, but there isn't any difference between the 08 & 09 is there ?
:cussing:
u can map each cyl with a pc3 in a nut sheel you get a 15% column to map that is about it
