12 volt battery and sensor cleaner. Clean in reverse first. Like you do a air filter. Injectors have a screen on them. This is the result
Be very careful about using a 12v source. I've seen several injectors get toasted that way. The injector coil isn't designed to handle 12v for more than a few milliseconds at a time and can over heat.
take note to this everybody. injectors don't just stay on. they pulse. same as nitrous. if your using a progressor then you need to be using a pulsed solenoid. thanks RansomTBe very careful about using a 12v source. I've seen several injectors get toasted that way. The injector coil isn't designed to handle 12v for more than a few milliseconds at a time and can over heat.
