Disabling Power Commander
I am trying to trouble shoot a fuel injector/electrical issue. My bike keeps cutting off while riding. My error code is reading c32, 33, 34, 35. I want to make sure PC is not going bad.
If you think the map is messed up you can load a "0" map. Otherwise you need to disconnect it to remove it from the loop. Follow the plugs and disconnect them from the bike. Then reconnect the bike plugs back together.
(Professor @ Jun. 03 2007,10:14) If you think the map is messed up you can load a "0" map.  Otherwise you need to disconnect it to remove it from the loop. Follow the plugs and disconnect them from the bike. Then reconnect the bike plugs back together.
+1 - Easiest way is to disconnect.
