Busa has about 3800 miles now and it's been 2400 since last oil change (Mobil1 Syn). Initially filled it with 3400ml, showed middle of the sight glass, 1000 miles or so later it was at the bottom of the window so in went another 200ml and it was back up in the upper middle of the window. This morning started the bike, let it warm, shut it off, waited 30 minutes, bottom of the window again. Put in another 200ml, check it again here in a bit.
It's not leaking so it has to be burning it, does anybody else's bike use oil? I know it's less than half a quart between 3000 mile changes but my last 2 bikes used no oil in 3000 miles no matter how hard I reamed them.
If this is normal it's no problem, I'll just keep a closer eye on it and add 100ml at a time to keep it in the middle of the window.
