If you disconnect the battery on the 08 busa, do you have to reset anything like the power commander or make any other adjustments when you re-connect the battery?
Can't recommend the Battery Tender Jr enough. Comes with leads you can leave attached to the terminals so all you need to do is plug it in each time you park the bike. It'll add years to the life of your battery.
Just make sure when u start it weekly to let the bike reach its max operating temp before turning it off. I normally wait for the fan to kick in two times as a rule of thumb. Not letting it hit the normal temp is bad for your head gaskets. Flaming welcome!
