nintastio
I've been reading up on ECU flashing since I will need to disable the pair valve in the ECU but a lot of the info seems either out dated or the links are broken.
Is using ECU editor still the way to go for a basic flash on a 2000 Hayabusa with a 2002 ECU? I see BoostbySmith is the go to vendor for this stuff, but I also read about building your own harness but again ran into a lot of broken links or missing pictures.
If ECU editor is still the way to go where can I find a guide on building my own harness? I am very comfortable with a soldering iron and a wiring diagram.
