DIY OBD Dashboard
Qaiss
Hey, I've been seeing these posts where people connect 2 pins to get FI codes etc.
Now if I'd do this, will the engine run?
If so, would it be possible to connect a 6 pin male together to get it's functionality as well?
So put the bike in permanent dealer mode and connect the 6 pin you see on the picture.
Basically I want to connect a OBD on my bike so I can have a dashboard running on my phone.
hi @Qaiss
hard conn of the two wires i guess won´t be a good idea i guess
better you install a switch (somewhere around the sppedo or so) and lead its two wires to the board-connector
to install a kind of OBD like in cars etc. i guess is not possible.
Thanks!
I've found out it's physically possible to combine a dealer mode switch with an OBD cable.
But software-based it's not do-able due to the SDS protocol of Suzuki, as Greg from boostbysmith says.
Although, I have seen posts on other forums, people reverse engineering protocols for other bikes. Maybe one day.
