Do I need a PC?
llbigbird
I am hoping someone can tell me.I have a 200 Hayabusa with 2 brothers slip-ons.I have come across a good deal for a Yoshi 4-1.If I buy this do I need a PC to make it run right.I am not really looking for HP gains but I want to change the exhaust.Thanks for any info.
To see the gains from the pipe I would invest in the P.C...
or at least make sure you remove the PAIR and use the Block Off plates....
(321CYA @ Sep. 30 2006,18:40) To see the gains from the pipe I would invest in the P.C...
+1
You need the PC to make propper adjustments with the mapping. Other wise the pipe will be there just for looks and sound. You may not even feel a difference on the bike if its not setup properly.
Didn't really read the reason for the question but chances are the answer is YES. Every Busa needs a Power Commander. Period.
