No, it is not a NEED, your engine will run safely without it. Your bike will run better with a base map loaded in a power commander from Brocks, and it will run it's best when dyno tuned properly.
The ecu editor does alot more than a power commander too, if you have a dyno tuner close by that tunes with ecu editor that would be your best bet. There's alot of info on this site about it, and here's a link to their homepage. boostbysmith.com - Home
to the oRg You have an 07, if you live in the US and have a US model I'm gonna say the bike is running lean and you need the PC or ECU edit to correct that because the bike won't.
