hi
@JeffSyh
i would recommend to get the original hose - not else one from else where
the original is, if i remember correctly, a bit pre-bent ? hmmmm
and at revzilla its prize is at only 16 bucks
and if you, when engine is cold, pull it off from the pipe at the cyl.´s connector (highest point in water circuit) you can
1st get its inner size (what you won´t need if you buy the original one
2nd replace the entire hose easyly because there is no pressure in it, when engine is off & cold, and only a lill sip of water would drip out
if replaced quickly
at the pump
good luck
