Same question for a III. Mine came with a 9 volt battery connector and I assumed that was for saving the map if bike battery was disconnected.
hey read up on the "rich/lean" buttons and tell me how they work.. I do not have the manual and to lazy to find one I know you can adjust rich/lean with the buttons but they revert to the original map when the bike is turned off, just not sure how to use them
PUT THE BIKE IN NEUTRAL , PUT A ZIP TIE AROUND THE CLUTCH OR HAVE SOMEONE HOLD IT ,SO IT IS ENGAGED AND HOLD ALL 3 BUTTONS DOWN ON THE PC, MAKE SURE THAT IT IS IN NEUTRALTHEN START THE BIKE WHILE HOLDING THE BUTTONS DOWN, ADJUST THE BUTTONS TO WHERE YOU WOULD LIKE, AND WAIT FOR THE LIGHTS ON THE PC TO GO BACK TO THE BOTTOM. ONCE IT DOES THEY PC SHOULD BE SET, THEN TURN THE BIKE OFF. TO MAKE IT RICH THE LIGHTS GO UP , TO LEAN THEY GO DOWN. DO 1 BUTTON AT A TIME !!!
NO CAPS LOCK UH !!!:rofl: OH WELL !!!
I DONT PAY ATTENTION TO WHAT THIS COMPUTER IS SET ON WHEN I TYPE, JUST TRYING TO HELP SOMEONE OUT AN GET THE CAPS LOCK COMPLAINT !!! ITS NO BIGGER THAN THAT PICTURE YOU POSTED ANYWAY JUST MESSING AROUND , DONT GO BLOW YOUR TOP
