GsxRzrGo-13
For my first post to the forum i will start with thanks for having me and also thanks for any help i can get. all of my posts will be related to bike topics but also since i do not have a bike just the motor they will all have a twist.
i have read about burping the cooling system and see the importance of it. i have two radiators on my golf cart. the coolant leaves the thermostat and heads to the front one. factory banshee. then it returns to the factory busa radiator. the second is much higher than the motor. i have the fan still attached to the second one. then the coolant returns to the bottom port on the motor. the breather that leaves the thermostat is direct into the second one. the motor is sideways in the cart and i cant shake it to burp it correctly as stated. any suggestions on how to get the air out? also i cant get the fan to turn on. it was my hopes to have enough coolant that it wont need to stay on but the gauge will hit barely above on the half way. if i jump the sensor on the radiator the fan does come on so wiring is correct.
