(Shibumi @ Dec. 03 2006,18:57)
(Charlesbusa @ Dec. 03 2006,19:57) If you are planning on dragg'in knee more than a few times, than I'd suggest tweaking on your suspension. You WILL run into ground clearance problems if you leave it stock. I've ohlin's internals in the front forks with a .950 kg/mm spring rate, I weigh 165lbs. Also, I raised the rear an inch, run a 190/55 series rear tire and added some comp and reb to the stock shock.
Hey Charles, I'm your exact weight, what settings do you have your suspension set on?
I'm lowered one notch on dogbones on the rear, and 3/4" up front with Pingel bushings. I've only got about 1/8" chicken strips left, I don't know if it will go any further without dragging things...
