Had the right side plastic off to do an oil change and noticed whatever was draining out of the tubes is causing the paint to bubble up and fall off the inside of the fairing. It is getting close to the back edge and could cause the paint to come off where it is noticable from the outside. I put a piece of high temp reflective tape over the spot but was wondering if any of you have had the same thing happen. Thought about relocating the tubes, but don't know where I could run them to cure the problem. Any idea why this is happening?
