Prop the front of the tank up with the prop rod. Disconnect the fuel line at the metal fuel rail. Turn the key on and use the on/off switch to cycle the pump for a few seconds as you drain the gas into a gas can. Turn the switch off, then on again until the tank is empty. I've done this for years to flush out the MR 12 fuel after a race. Works great.
U can buy a cheap manual transfer pump and pull it out. I have one that I use to pull oil out of my mowers because the drain is in the wrong fn place!
Troy
