Posted on the gixxer board, I find this dialogue:
"The stuff you spray on the chain just attracts and holds dirt. It's a relic from the days before o-ring chains when lube actually did matter.
"None of the stuff you spray on the chain is stout enough to be providing any sort of cushion between the sprocket teeth and the chain. It just gets pushed out of the way by tons of pressure.
"O-rings are malleable rubber and do not need to be lubed to stay pliable.
"Clean your chain, align your chain, properly adjust your chain. That's it."
I'm VERY interested in your opinions of this. It makes a great deal of sense, actually, but before I test it out on a chain of mine, I'd like to know.
Part of the reason it rings true to me is that when I first started using the Chain Wax, I had this thought that if you use wax or other lubes which attract junk, will they be likely to damage the O-rings?
I've wondered that ever since.
--Wag--
--Wag--
